Gadget’s are causing trouble – does seem to work
Desktop gadget are not working. Each time I activate a desktop gadget it just blur and not much is visible. I cannot run even the newly downloaded gadgets. I need the solution as quickly as possible. Kindly someone help me with the issue.
Jeremiah Mai
Answered By 590495 points N/A #110221
You did not explain well about the gadget you are trying to use. If you are pointing to the software of your device that does not work after you open it on the desktop, check if the device needs to be connected to the computer first before opening the application and then try it again. If it still does not work, try uninstalling the device’s software from the computer. Next, check your machine for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks.
After checking the hard drive, install the application again. This will fix any corrupted files in the installation and will restore its settings back to default. If, on the other hand, the software still doesn’t work, check the program’s system requirements. It is possible that the software is not compatible with your operating system. Just replace it with the right version that is compatible with your Windows.
