alanjayason
20 points
Posted on - 09/03/2012
Hi Experts,
I want to gain access to sms profit application.I tried to access sms profit application but failed.It did not authorize me to continue.Can you advice me on accessing sms profit application.Thanks.
Alanjayason
Gain access to SMS profit application ?
If this is the first time that this happens, try restarting your computer then try it again. If the application you are saying here is already installed on your computer, try doing a clean installation of the program again to fix any corrupted and missing files that may have developed. Uninstall the program then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. Install the application again after this then see if you are now able to use it.
You should also check the system requirements of the program to verify that its version is compatible with your operating system. If it doesn’t, then just download and install the version that works with your platform.
