FidanoskiF
Posted on - 08/17/2016
Hi. I am a student currently pursuing my BTech in Electronics. I am keen on knowing how to convert SWF to FLV. Could you please suggest me the steps to do that? Thanks a lot. Please reply ASAP.
Gain Some Technical Knowledge By Learning How To Convert Swf To Flv
Hi. To learn how to convert SWF to FLV, first download and install the software FLV video converter factory pro. Then, double-click on the software to open it. On the screen, click on the add option. Then, in the profile option which appears towards the bottom of the screen, add the output format in which you want your file to be. Next, to start the conversion, select the start option. Then, click on the open option to view the converted video.
Alternatively, the software Faasoft SWF to FLV converter can also be used. First, select the SWF file which needs to be converted to the FLV format. Then select the output format which is FLV. The video can be trimmed, edited and cropped by clicking on the Tim option after which a video edit window appears. Then click on the convert option finally and wait while the conversion takes place. Hope we helped.
