Wanna ask?if we can connect galaxy ace with windows media player?what is the memory card for the galaxy ace?Can we add different languages?does the widget show the weather forecast?
Thank you so much
Janet
Galaxy ace player media widget
In order to connect your Samsung Ace to Windows Media Player on your pc, you have to directly connect your mobile to your system via USB cable. Go to your control panel and select devices. Then check whether your mobile appears as one of the devices that is connected to your pc. After confirming, open your Windows Media Player and go to SYNC tab then select your Samsung mobile.
As for Samsung Ace memory card, it uses a Micro SD/SDHC type. Your mobile phone has an internal storage of 150MB and if you want to expand it, I suggest you get a 4GB micro SDHC memory card.
Instead of adding different languages on your phone, I suggest you go to its Settings and change its language. Samsung has the option to change the settings from English to some other language you know.
If you want to have a widget that displays not only the time but also the weather forecast, I suggest you download your preferred widget online or via your phone’s Google play store. Check this website https://mob-core.com/en/samsung-s5830-galaxy-ace/vidzhety/ for some cool widgets that can be installed on a Samsung Galaxy Ace 5830.
