anonymous
7060 points
Posted on - 10/12/2012
I sat on my Galaxy tab down last night after work and when I tried to use it today it won't boot up. I've tried a hard reset and plugging it into the computer and the wall charger with no change. Anyone have any ideas? When it's plugged in it doesn't even show that it's charging.
HELP !!
Galaxy Tab SCH-1800 boot up issues
You need to try two things. Press and hold the power button and count till 15. This is the reboot process. If it doesn't works then please adopt the second procedure given below.
Hold down the power button and volume up button for 10 to 15 seconds. Logo will appear on the screen. Now you can release the power button and use the volume button to scroll up and down on the menu and select 'Factory Reset'.
Last option is to visit the service center with your warranty card in case all the above procedures failed.
Best of luck.
