Hello Guys,
I am having challenges to remove Google login names from the web servers so that software from the android store can download properly. I have a working email account at Gmail and I need to eliminate all the above.
Thank you in advance for any help.
Galaxy tablet/Google [from Other OS]
You should first log out from your Google account, so that your account doesn't get recognized as the one downloading the software. You can also disable auto fill-in of names saved in the browser or alternatively clear web browsing data or history from the settings to clear saved names and auto fills. Thus this should enable you download without identification.
Hope that helps out.Â
You can easily resolve this problem by following some steps which you have to perform.
Open your Web Server and log out all the names you enter in the simple way.
You can resolve this issue if you access the settings then clear all cache from the Web browser's history.
You have to use only 1 account to open Google store and it will save automatically.
You can easily download the applications without any problem.
