Galaxy Tim USB bridge is exact to do many operations
Hello expert,
 My brother is using a Samsung Galaxy S3 mobile. He needs to speed up his phone’s USB transfer. I think the Galaxy Tim USB bridge is exact to do this operation. Is it possible way to speed up my brothers mobile?
Best Answer by Garrison Roger
Answered By 0 points N/A #179359
Samsung Galaxy 3, is the smartest phone available in the market, except the battery life, no phone  is there to beat the Samsung Galaxy Phone. Now as per your question goes, Galaxy 3 Tim USB data sharing is up to the mark. Honestly speaking it is quite fast while data transferring, however if your phone is slow for some reason , please refer to the manual, or contact Samsung customer care.
Thanks
Answered By 0 points N/A #179360
Samsung Galaxy S3  has one of the best processors with a good speed. However, if you are still facing problems you can go into Settings-> developer options-> and Window animation scale and Transition Animation scale -> change both of those to 0.5x (or 0 for both, for instant reactions). The phone will run faster than before. The problem of speed will be resolved.
I hope this helps you.
