Game Booster error message on Windows 7
I have a Windows 7 32 bit Professional machine with 4 GB memory and 200 GB free hard disk space. I have Game booster software installed on my PC.
Since I am more into the latest online games and downloaded games, I had this software application downloaded. This software optimizes my computer for a smoother and better system performance while playing games.
It updates the hardware drivers, tweak the system and I find this software very useful. But from quite a few days I have been getting this error message.
Game Booster
Could not convert variant of type (Null) into type (OleStr)
Has anyone come across an error message like this?
Best Answer by Sammy1
Answered By 0 points N/A #87160
Good day.
I strongly suggest to uninstall and reinstall the program from the system. Since you  are more into online gaming a deep scan of the system would be highly recommend this is to check for registry errors. Though this program optimizes your computer, it still adds to the work load of the computer processing. Make sure that the software is not conflicting with other 3rd party programs on the computer.
Answered By 0 points N/A #87161
Good day,
This kind of issue occurs due to incompatibility of the system. Try to check your Windows system if it is 32 bit or 64bit running. Most of the game booster runs with 64bit. Try to uninstall that program and find game booster software, compatible in your system.
Thank you. Hope it helps.
Regards;
henjobeth
Answered By 75 points N/A #87162
To injection the mistake of the game booster.exe to your computer you just simply transfer the Connect game Booster.exe Mistake injection tool and then after that just delay for the apprise to be finished and then simply presentation the injection tool and then just connect the Overhaul to injection the mistake from the game booster.exe just delay for some minutes to finished the skimming from the CPU and then if the your CPU poisoning any worm or possibly malware to your CPU your just simply reboot your diseased CPU and then enter the method just press F8 to allow you to usage the Advanced Options menu just simply press ok then pause to moonboot the harmless style with interacting and then just simply press windows and R important to route your computer then connect the game booster.exe diseased worm elimination instrument and inform after the transfer is finished.
