Game character issues – “Error on your character select
I faced a weird problem. To see the name wrong, I made this character and then loaded into the game. I tried to delete/remake. Then I see in the deletion prompt and the name is spelled correctly there.
Then an error message shows “Error on your character select”.
Need Solutions. Thanks a lot.
Answered By 590495 points N/A #90339
You have very incomplete information in your post. You didn’t put what game it is you are talking about or the version of Windows you are using. But anyway, either you are playing an online game or a stand-alone offline game it still needs an installer for the game to be installed on the computer. If you noticed some weird things on the game like the misspelled character name, try uninstalling then reinstalling the game you are playing. If still nothing happened, if it’s possible to download another copy of the game’s installer, download it. Or if it has an available patch on the website, download and install it to apply the improvements on the game.
You may also try checking your computer for any possible errors in the file system. Use a disk utility application to analyze your system. For a much thorough diagnostics on your system, use a disk utility application like Norton SystemWorks, Norton Utilities, or PC Tools Performance Toolkit.
