elenigmn
Posted on - 11/03/2012
I have made built gaming computer. Everything works appropriate but when I click at the volume the game freeze. I do not know what my mistake is. May I have some suggestions? Maybe my videocard?
Thank you,
Eleni G.
Game Freezes on Custom Built Gaming PC
I’m going to assist you in solving the problem with your PC. Your gaming computer seems fine. But you need to know that gaming computers are very heat sensitive.
Because of producing a lot of heat the CPU and graphics processor run very hot. I would like to recommend you to check if powerful propellers as well as coolers are installed in your CPU chamber. Because of getting extremely hot, computer hangs. Your problem may be caused by such heat issue.
So you’ve got to observe the CPU and GPU temperature and keep your PC in a cool and dust free area.
There are many such problems that can damage your hardware as you made a high configuration gaming pc. This kinds of pc usually makes problems when you create extra pressure in it. There might be a problem in the ram or the sound card. Reinstall them. That might solve the problem.
