ney steele
20 points
Posted on - 06/21/2012
Hi everyone,
I just got a problem:
After I have installed the game “ Hyperbowl” successfully the following error message pops-up when I add the original disk in the tray that was provided with the install. The error
message was:
Error Z0001: Internal error
I am using Windows XP SP2 now.The options given with this 'OK' and ‘Cancel’ only. I’m counting on you guys. Thanks for reading.
Game installation error : Internal error?
Dear Ney Steele
Error Z0001 is a common error for XP sp2 users.
Now I am telling you the exact way for solving this problem. It’s free and simple.
When you run older CD-Cops protected program under XP SP2 you will face this problem.
01. For solution you need to contact manufacturer for collecting a free patch program that will fix this error.
Another option you can choose to solve the problem is:
02. You can update your existing XP SP2. You can get update from update.microsoft.com.
If you update your product you need not to worry about errors because update products are error free.
Hope you will be satisfied with this solution.
Hello Dear,
Microsoft pop up blocker is the main cause of this problem. Although third party pop up blocker must be the cause of this problem. Here is the solution for you:
1. At first, you have to configure the Pop up blocker
2. Open internet explorer from start menu
3. Go to tools option from menu bar
4. Go for the Pop Up blocker setting
5. There you will see the address of web
6. Click on allow. There you need to type http://www.update.microsoft.com/windowsupdate/v6/thanks.aspx?ln=en&&thankspage=5
7. Add this address
8. Apply this setting
I thing this problem will never bother you
Thanks for having your time
