Marty
20 points
Posted on - 09/23/2012
I was playing LOL then logged of to get something to eat. After that I went back to play again. I was in the middle of the game when it crashed. I tried to log in and this message appeared. I tried the firewall but still it fails to connect. What could be wrong? In between the time I logged of and logged in again there was no one using the computer.
League of Legends
Failed to Connect
Unable to connect to the server. If you have a firewall, it may be blocking the connection. Please refer to your firewall’s documentation. Would you like to retry the connection?
Game: League of Legends; Failed to Connect to the server.
Good Day,
Have you check your internet connection if it is intermittent or not?
Try browsing some websites to check if you have an internet connection before connecting again to the game.
What did you do to your firewall?
Try turning off your firewall.
1. Click on Start
2. Click on Control Panel
3. Click on System and Security
4. Click on Windows Firewall
5. On the left side of the screen Click Turn Windows Firewall On or Off
6. Select Turn off Windows Firewall.
7. After that Run the game again
Hello!
This kind of problem happened to many people, so it seems it because something goes wrong with their server. The only thing you can actually do is to wait for them to fix this problem. I would not advise you disable your firewall, as it protects your pc from other things beside LOL, and you have more to lose than you may gain by disabling it. You could try playing on a different server meanwhile.
Good luck!
Hi Marty,
As well these solutions you can fix this problem by following another techniques too. Go this Techyv page, there you will get some new techniques to fix this issue.
Failed to Connect to League of Legends Game
