kevin black
Posted on - 12/03/2011
Please help me on Problem with connection with game server in online games failed.
Thanks,
Tony Stevenson
lee hung
75 points
Game Server In Online Games Failed
This error will occur if the game server is not responding. This will happen if the server is changing something on their games, A Crossfire game is very popular for example when they have a new character or weapon to put on there game, all they have to do is to cut down there connection for an hour and upload new settings on there games. That's the reason why you can encountering this error "PROBLEMS CONNECTION WITH GAME SERVER". 2ND is always check your internet connection, this is also the error display if you click the icon of the game you want to play "PROBLEM CONNECTION WITH GAME SERVER". Patching is also different because when you click the unpatch icon it automatically download the lacking program. I think that'sÂ
all. Feel free again to post here.
Thanks,
Tony Stevenson…
You probably know that for you to play online games you will need to have a computer that has a large amount of memory space, and to be precise the RAM should be about 6 GB for the computer to operate a good speed when playing games. Another thing you should know about online games is that they require you to be having a high speed internet connection, for they require a lot of bandwidth to be able to load.
So the two things that will advise you to check on are:
Internet connection speed- It is slow, then you might need to close other tabs or pages you have opened that are consuming bandwidth for the game to load faster.
RAM capacity- You will need to upgrade your RAM capacity in case your computer is running on low memory to up to about 6 GB as I had mentioned.
Regards
Thompson Locker
