Game software error with message
As soon as i try to open the game I receive an error prompt that reads data 2 is not ready.
This kind of prompt first appeared at the time when I bought this game, but the thing is I cannot recall the steps that I took to correct this or Incase if I took any steps!
All I know is i used if after that, and it worked properly.
Does anyone know what steps I can take to do away with it?
Answered By 590495 points N/A #103768
You did not mention the name of the game you are having problems with.
This would help you know the compatibility of the game on your operating system.
But anyway, since you did not mention the game’s name, the only solution that is possible is to check your computer for errors.
I couldn’t verify if the game is compatible to run on your operating system.
Use a disk utility application to check your hard drive for any possible errors that it might contain.
If you don’t have one installed on your computer, you may use Windows’ own disk check tool just like what is described below.
  1. Right-click drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now.
  4. Check Automatically fix file system errors then click Start.
Run the game again after checking your drive for errors.
If you see the same error again, try uninstalling and reinstalling the game.
