Game won’t install on Xbox
I bought the DC Spotlight game for $5 on Xbox and it just wont install. I have tried reinstalling repeatedly but it just pops a message saying installation stopped. I have checked my internet connection and it is okay. What could be the cause of the problem? Is it the game of my Xbox? Has anyone had a similar issue before?
Answered By 0 points N/A #186911
The main cause of the problem of not installing your “DC Spotlight game” of the “Xbox One” gaming console is due to the installing of the game into the hard drive and downloading updates of the “Xbox One” gaming console at the same time which has causing the problem.
Yes, it is the game of the “Xbox One” gaming console.
To resolve the problem of not installing your “DC Spotlight game” of the “Xbox One” gaming console follows these few steps:
· Firstly, totally uninstalled your “DC Spotlight game” from the “Xbox One” gaming console.
· After that, turned the router off.
· Then, successfully re-installed your “DC Spotlight game” of the “Xbox One” gaming console.
Hope this answer will help you a lot.
