What do you mean by game booster?
How it gives benefits to gaming technology?
Gaming and its latest technology
Game Booster optimizes your game performance to your PC in one click Windows only. If you have some problems about your running applications, clear out RAM, update drivers, and in another way to get your system ready for playing games, the free app Game Booster will be the one to do it all for you, base to your preferences.
Game Booster provides you a number of preferences and options for when you're running a game, which leads the background applications can quit to small twist to optimize processor performance and clean RAM.
After defining your preferences, you can go directly into "Gaming mode" with the spin of a switch. When you're done playing, you can just switch off the gaming mode and go back to your regular desktop.
It also has unique features, like to check the important driver updates, to download popular game add-ons, and to defragment your game files.
If you think and it’s proven that your desktop setup isn’t best for gaming, it's a likeable tool the lets you spend more time in gaming and less time twisting your computer before every session.
Game Booster is an easy-to-use program that shuts down unnecessary system processes in order to improve the performance of resource-thirsty games. With an intuitive interface that makes it easy to switch between gaming mode and normal mode, Game Booster is a simple but powerful program.
You might ask how can it speed up a game. Well, the simple answer is found with how fast your computer will function. RAM, also known as random access memory, is one factor in how fast your computer will function. Game booster closes all of your unwanted programs in the background. (Most all of the things going on behind the screen) With a simple push of a button Game Booster will change modes and turn into a key tool in revving up your games. Game Booster's interface is basic, with a list of 24 noncritical processes that can be shut down during gaming.
Check boxes allow users to select specific processes. It is true that you have to take a leap of faith with some of these; if you're not extremely computer savvy, you may have no idea what it is that you're shutting down. We can say that our system suffered no Will effects from temporarily disabling all of the listed processes, and the program quickly started them again when we switched back to normal mode.
GOOD
It closes all unnecessary programs that you have configured prior to running it. It will quickly defrag. The game file. It will run the boost and launch the game at 21 clicks of your mouse. It even monitors the temperature of your CPU, MB, Graphics card, and fan speed. It will give the running game program, max. CPU priority over any background prog. I run a Pent. 4 w/Ht 3.Gig, with 2G. ddr2, 256Mb ddr3 gt240 video card. I've been playing games on it that were at minimum system requirements.Now I run the same games with higher graphics and higher resolution.
BAD
Nothing so bad. The majority of speed still depends on your hardware.
Summary
If you have a high-end CPU you will think this program is a scrap but for older CPU its somehow increase your gaming experience with the increase of FPS by 5-7. It optimized my PC well like any other optimizers. Give's a clear and thorough detail which I needed to boost my PC. It's like back for the buck but it's free.
