casey cock
30 points
Posted on - 08/22/2012
Hello,Â
I am working with Gantt chart. My Gantt chart has more task than it will fit on one page. But I want to continue them on a second page. Now I am facing difficulty to make a breakage on them. So what should I do to access on second page?
Eagerly waiting for some help. Â
To do this you need to make a title format for the page to reflect the titles in the first column to appear in the second page.
in MS Excel go to page layout then click on print titles a popup windows will appear. select the rows or columns to repeat by clicking the small icon in the far right of the input box.
the dialog box will change to a single text box and you can highlight the area where you want to be repeated in the next page.
Highlight the area to repeat and press enter.
view your document in print preview and adjust your page breaks to your liking.
I hope this helps
Thank you
