Hi all,
I have been trying to install the Garage Band Jam Pack music software, but it won't install.
When I start the installation, it gives me the following error message:
Install GarageBand Jam Pack World Music
There were errors installing the software
Please try installing again.
Go Back Close
Please can anyone tell me what might be the reason behind this error. I'll be really thankful.
Looking forward to your comments.
Araceliariana
GarageBand Jam Pack music installation error
Hello Arace,
First thing you will need to check is if all the Jam packs appear in GB or did they not install. Also, you will need to check if the Jam Pack you are using is the most recent one or it is outdated. In case it is outdated you will need to obtain a recent one and use it for installation.
Nicke
You're using an Apple Mac computer. To try to check the game information if the requirements apply to you mac computer operating
system.if your using a none original CD this will have errors also some pirated software have lost files that make such kinds of errors, so it's better to have an original game CD in hand
