Garmin Oregon 450 Screen Problems
I just bought a Garmin Oregon 450 a few months ago. It worked fine at first, then after several months, the display either go farther to the right or farther to the left. I have to recalibrate the screen almost as frequently as I am using it.
It also kept jerking to the right and I could not push any icons. Is this the cause of the new Garmin update I did?
What can I do to fix this problem?
