Gateway Error Code 0xc00000e9 Causes And Fixes
What is gateway error code 0xc00000e9? How is it caused? What changes must I make to my system to solve the error? Thank you in advance.
Error Code 0xc00000e9 is the most common error. Users witness a blank screen when you try booting your PC. The reason this error occurs is that the different PC components are not properly connected to your PC. Also, corrupt system files or malfunctioning hardware are also some reasons. You should try to do this:
Method 1:
If the above option does not work, you must try doing this. Try recovering your boot files. For this:
Method 2:
That is an input/output error or I/O error and basically refers to a device or hardware installed on your computer. It can be your internal hard drive, optical drive, USB flash drive, and others. If your computer can’t boot and you see this error on startup, the first thing to check is your internal hard drive because this is where the operating system is installed.
If the connection between your computer and the hard drive is faulty, you will likely receive an I/O error and you won’t be able to boot the computer. To fix this, turn off the computer then open the CPU case. Next, disconnect all the cables from the hard drive. After this, connect the ribbon cable or data cable back to the hard drive.
For the power, use the other power supply cable to plug to the hard drive. When you are finished, start the computer then see if it works. In case you are using a laptop, check the optical drive if a disc is inserted and remove it.
You won’t be able to boot your computer properly if a disc is inserted in the optical drive because the machine will keep booting the system from the disc.
