emmamorales
10 points
Posted on - 03/15/2012
I Installed mail server zimbra on Ubuntu 10.04. It run perfectly.
But the problem is my Zimbra can't receive and send email except emails from the database.
Is there any configuration so I can send and receive email from all?
Gateway-forward and domain setting at mail server zimbra
There can be a dependency issue in the server that you are using. So i would recommend you to do the following.
First of all, the email addresses to which you want to send and receive the emails, put them in the database at first and then proceed. Now use them and do any kind of sending and receiving to which ever email address you want to.
Sometimes it is not necessary that you have a shortcut to everything and that you have to do it in this way. Though it is lengthy but from the problem that you have described seems to be the only solution to this problem.
