James Gary
Posted on - 12/06/2011
 I am new user of LotusScript and Lotus Notes. Can I gather data from database using Notes View? Anybody please help me, I designed SQL (related) table for every Notes Forms, then tried to gather data using Notes Form and store that in corresponding table but I couldn’t make it. What shall I do?
Gathering data from database using Notes View
You will need to understand that a view gives you the ability to view anything in lotus notes, and some the things you can be able to view include the following:
Your mail
The calendar items.
The To Do list.
The view will enable you to quickly find the information that you need. As for viewing information in a database, you can have more than one view and then look at the documents differently. In case you need to view all the information that is contained in a database in lotus notes, then you will need to do the following:
Go to the lotus menu bar and there click on show.
Click on selected only; that will turn off the feature.
Once you have done that, all the documents that are in the database will be visible again.
Regards
Thompson Locker
