Hi Friends, Does Gear Pro 7 support Windows XP, Please advise on where to get the trustable premium version of Gear Pro 7 from the internet. Please do the needful for providing me the features of it, also suggest me the best alternative software for Gear Pro 7 that will work in Windows XP. If I can get a free download, that will be great.
Gear Pro 7 or alternative software for Windows XP
Hello
Yes Clive, Gear Pro support Window XP along with Vista/7/2000.
To download the premium version of Gear Pro, there would be no more trustable site than the Gear pro itself.
Click on this link here
Some of its features are – converts cd and DVD to ddp images and burn ddp images, it can copy disc to multiple images and also it can control the system formatting.
Hope this would help!!
Thanks
Bennie
Hi Clive,
Gear Pro supports Windows XP not even XP it also supports Windows 7/ Vista. You can have a premium Gear Pro by purchasing it. Go to this link so you can then download the trial version of Gear Pro.
Gear Pro features are Powerful Multi Tasking, Support Latest Formats, and  Easy to Use. I don't know if there's an alternate software like Gear Pro but if you will just burn a CD you can try this software it is free and easy to use.
Hope I helped you best regards.
