I need to update the graphic card on my computer, and I am trying to find the best solution for my budget and for my gaming needs. The GeForce GTX 750 Ti and the Tadeon R7 265 are both within my price limit.
Are there significant differences between the two? Is there a consensus on the best one?
GeForce GTX 750 Ti vs Radeon R7 265
I think, the Tadeon R7 265 is better than the GeForce GTX 750 Ti, because:
Sl.
Features
Tadeon R7 265
GeForce GTX 750(/760) Ti
Pixel Rate
28.8 GPixel/s
16.32 GPixel/s
02.
Texture Rate
57.6 G Texel/s
94.1 Texel/s
03.
Floating Point Performance
1,843 GFLOPS
04.
Shading Units
1,024
640
05.
Texture Mapping Units
64
96
06.
Compute Units
16
For your more information, the number of the user of GeForce GTX 750 Ti is greater than the user of Tadeon R7 265. But you can take your own decision on the view of the given table. Â
