General Block Diagram Of Motherboard And Analysis
What is a motherboard? What are the parts of the block diagram of a motherboard? Why will the diagram be helpful? What are the other names of the motherboard?
The motherboard is also known as the main board, baseboard, planar board or system board. It is the main printed circuit board found in devices. It holds and allows communication between many electronic components of a system. The CPU and memory are connected to the motherboard; it has many peripherals to connect to input/output devices, memory controllers, interface controllers and other components for general purpose use. The block diagram will help you to replace the motherboard and to do other upgrades like add RAM or Graphics card.
The motherboard in a computer is a PCB or printed circuit board and the foundation of a computer. It is the biggest board in a computer chassis. It distributes power and allows communication between the CPU, RAM, and every computer hardware component. It provides connectivity between the hardware components like the processor or the CPU, memory or RAM, hard drive, and video card.
There are many types of motherboards designed to fit different types and sizes of computers. Every type of motherboard is designed to work with particular types of memory and processor that’s why they don’t work with all processors and types of memories. Hard drives, on the other hand, are universal in majority and work with the majority of motherboards.
Below is an example of a motherboard from ASUS.
The motherboard is located inside the computer case. It is where most of the parts and peripherals are connected.
