joelabrame
10 points
Posted on - 11/27/2012
Hi Experts,
While installing VMware Tools I received an error message. The screenshot of the error message is as under.
I have no idea for the internal error. If you have any idea for the internal error, please help me to install it.
Thanks in advance.
Error on
A general system error occurred: Internal error
The " A general system error occurred: Internal error." message is very generic and does not reveal the actual problem. The windows.iso is available within the /vmimages/tools-iso/ folder of the ESX host.
You have to check the license period of the VMware. If it is licensed then reinstall it after rebooting your computer. Thank you.
Dear Joelabrame,
The main reason for this error is that VMware is unable to determine the suitable tools needs to be installed to configure settings for guest operating system, as the type of this operating system could not be determined, so you can avoid this problem or error message by making sure that VM shell has adjusted the suitable operating system for the guest operating system.
