Generate VBA Code in all versions of Excel through Macro Reader
Is it possible to generate a VBA code in Excel by using Macro Recorder? And is it compatible in all versions of Excel?
 It is possible to generate a VBA(visual basic for applications) in the excel spreadsheet by using the macro recorders .Macro Recorders is very beneficial tool include in Excel VBA. You can records your task .first all of all you recorded a task then accomplish the task  over and then over with the button. While doing this you can save a lot of time. Macro recorder is very useful when you have no knowledge of how to bill a specific task in excel VBA. Open the VBA editor and then recorded the task. It is compatible in all versions of Excel.
