While working in contributor web and using export to excel system I found some problems. Generation of multiple worksheets loaded with a message as error code 0x80070057. I could not solve the problem though tried various options. Help me get rid of this problem.
Generation of multiple worksheets loaded with message error code 0x80070057
Well Payton,
The problem error you faced 0x80070057 is not from excel system, it’s a windows virtual memory problem error. You must increase your virtual memory while you need to export a huge worksheet to excel system. The process is go to system security in control panel click system then advanced system setting go to advanced tab and click setting under performance than again advance and increase the value of virtual memory up to 4k. Now take a restart for your system to take the change effected.
Hope your problem is over.
Hi James,
       This is a file disk error on your Hard drive, if your computer has a built hardware test try to run one for your Hard drive, as this may cause issues in the future. Here are the solutions that can help you resolve the problem:
Try to disable start up programs.
Try to run a Start up repair.
Try to run a check disk If issue still persist.
