Generic joystick drivers for Windows XP
Hi guys I recently bought a new joystick. But my old xp is failing to install its driver. Do you know any generic joystick drivers that may help to make it working?
Hi there,
I can provide you with some links, kindly download and install using these safe sources.
These drivers can work with any Generic game pad, joysticks or control devices made by China, or any other third parties or with no brand names at all!
These drivers are fully functioning and are fully tested on Windows XP (All SPs),XP32 ,XP64 ,2000, 2003, Vista32, Vista64.
Hi Liam Sam,
You can download the driver from the following link provided below .While downloading the driver select the driver version for specific to your laptop OS. As you are using Windows XP select the link to download from XP OS. Also download only the version specific to the manufacture of your joystick. I think this will resolve your issue.
Andrew Shakava
