Genie Scout 12 v1.00 beta 2error
I am using Genie Scout 12 version 1.00 beta 2 but receiving an “Error Loading Entity Number: 0”. Help me to resolve this matter. Am I using the older version? Any help would be much appreciated.
Thanks
FM Genie Scout 12 v1.00 beta 2
File Position: -1
Database Version: 1686
XML data seems to be corrupt.
Please make sure that you are using the last version of the FM Genie
Scout and that the file is not corrupt.
If you are sure and still see this message, please send the dump file with information of an error to my site
(use Report Bug from menu Help and Support) and it will be fixed in the near future.
Dump files are kept in the same folder as FM Genie Scout.
Thank you for the cooperation.
Filter Type: 7.
OK
