Ecas Roudaf
Posted on - 08/09/2011
I am using genuine Windows XP. While using this operating system I was download some files from “rapidshare” server. These files have some attached files and I was clicked one of file which corrupt my windows and after formatting windows not accepting the genuine version and remain as unregistered version.
How it will recover?
LoisP
Genuine Microsoft Windows XP corrupt
Good Day,
You may activate your Genuine Windows XP over the telephone. Please access product activation wizard then select automated phone system to activate, select your location and get your confirmation ID. You must call the toll free phone number that appears on the wizard screen.
Please see the links for your reference:
List of phone numbers
procedure to product activation
LoisP
That’s because the previous installation of your Windows XP before it got corrupted was already activated and does not require to be activated again. And when your operating system crashed and got corrupted, you need to install Windows again. But of course, since it is a new installation you still need to activate it after the installation. Windows XP is not automatically activated after its installation. Activation is done manually. You need to go online to activate it.
If you are downloading any kind of files over the internet, don’t forget to scan it first after it has been downloaded to be sure that it does not contain any virus or any kind of malware. I think that’s the reason why your operating system crashed.
