Hi there,
I have downloaded the latest version of Geogebra v 4.4.1.0 and everytime I start the application, it starts loading then goes off unexpectedly without any popup or dialog box, what could be the problem? I have tried fresh installation and still experiencing the same problem, I have Dell E6400 running on windows 8.1. How can I solve this one?
Geogebra not working properly on Windows 8.1
You should first Try CCleaner, uninstall the Geogebra software, fix registry issues, clean up junk files.
Then install Fresh copy of Geogebra
The file you have downloaded may be damaged or corrupt. You can go to GeoGebra official website and download the latest GeoGebra 4.4.40.0 version from there. There are also download links available for Chrome App, Ubuntu and Mac OS X.
Download GeoGebra latest 4.4.40.0 version
Before installing, you first need to remove any traces of the GeoGebra 4.4.1.0 that you just installed so it won't have any conflicts. Remove from the Control Panel and remove any registry keys or files associated with it. Then continue installing the 4.4.40.0 version.
