jasonescalo
30 points
Posted on - 10/02/2012
Hello Experts,
I just want to ask, does Gestures Lock Screen on CM 9 allows you have the ability to keep the status bar viewable during a full screen app is running. like when watching a video, could I still see what time it is and view my notifications? And by the way, is Gesture Lock Screen availed on CM 9?
Thanks
Gesture Lock Screen on CM9
Hi Jasonescalo,
The Lockscreen Gesture is not available on CM 9.
Although the Lockscreen Gesture on CM 7 did allow the ability to keep the status bar viewable during a full screen app (e.g. while watching YouTube). Both the features have been left out on CM 9 or any later versions.
There has been a feature request on Google code for lockscreen gestures on CM9 but it has been notified that CM9 is feature frozen and is no longer supported for further enhancements.
You can still slide down the notification bar and select any power widgets from there.
Hope this helps.
