Get an AVG error during installation (error code 0xc0070643)
I receive this error message in Windows.
The error code is 0xc0070643 could you please let me know on how to avoid this?
Best Answer by Jeffrey Atala
Answered By 15 points N/A #145300
Hy,
I can not find any error message in your uploaded screenshot. May be you forgot to add AVG installation error message in your screenshot. AVG is very common antivirus to install every computer for a basic user. You can get error to install that software in your computer, if you had installed any other anti virus in your computer before install AVG Anti Virus.
So you should remove your previous anti virus form your computer to install a new anti virus as like AVG.
You may get database error too after install this anti virus. You can resolve that issue by update database from internet with latest update.
Thanks
Answered By 0 points N/A #145301
Hai there.
1 Log onto your computer in Safe Mode.
2 Right click on Start button and select explore.
3 Scroll down to Program files and open and then scroll down to AVG Folder.
4 Double click on this folder. You may see other folders with AVG 8 for example. if you right click on it and see if this will delete.
(I had AVG 8 9 AND 10 ON MINE) One of the folders it will not let you delete it. Once you have removed the folder/s that can be deleted open up the folder that cannot.
 5 Delete all that you can in this folder either by deleting one by one or in little chunks until you are only left with a handful.
These are the ones that will not delete until you do the following.
6 Open up the Task Manager by right clicking on the blue bar at the bottom and select Processes.
7 Now end the AVG Processes and then go back into the folder and delete the rest of the files. Once done you can then delete the AVG Folder.
Close this down and then restart your computer and you will be able to install AVG 2011.
Problem solved!
