a.shred
10 points
Posted on - 01/04/2012
I was using a peripheral storage device as duplicate data for a particular network storage link. Not long ago my computer system started to not recognize the integration and as a result, I tried to switch my network storage for another one. To make it functional, I had to restore my peripheral storage’s system; midway.
I realized that I was not able to duplicate some of the first files but the system had already started removing some files when I terminated the process. I would like to know if there is any way I can get back the data lost from the restoration?
Get back the data lost from the restoration?
Recovering the data which has been lost or deleted is not a big deal. There are some software by which you can easily recover your data, but it is only possible when you don't saved or installed anything after removing that items. Doing this means you have overwrite those files in place of deleted or lost files, then you cannot recover. But if you didn't overwrite anything then there are some free and also some paid software which are available online. Like; Disk warrior and data rescue these both software are paid while recuva is a free software by which you can also recover your data easily there are also some other software available online you can Google it.
GHANA KLOREN
