Get Closer To Technology By Learning How To Put Music Into Itunes
Hi. I am a student who has recently bought an iPhone. I want to transfer my songs from my PC to the iTunes library. How to put music into iTunes? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #111228
Hi. To learn how to put music into iTunes, first, open iTunes and then click on the option of showing the menu bar thus making the menu available. In the PC find where are the songs which you want to add are located. It will be better if you organize all of them in a folder. Make sure that the file extensions are amongst aac, mp3, Wav, AIFF, aa or m4a to be compatible with iTunes. Select the file menu and then select an option of adding to library which needs to be selected. Had you selected the option of adding the file to the library, then one song each would have to be added one after the other.
Look for your folder in the new window which appears, click on it and then select the folder to copy the folder to the library. After the folder is selected, wait for the folder to get added to iTunes library. The browsing window will close for a few seconds while the transfer takes place. The folder will automatically appear once the copy has been done.
Hope we helped.
