Get deleted files in MAC
Hi, I' m using a MAC OS and recently I had a partial crash of my hard drive and some of the data has been lost. I have used the in-built MAC volume software. But that is of no use. Could you please let me know of a software to get my deleted data back. Thanks
Best Answer by oliverpowell
Answered By 0 points N/A #88950
Hi
The problem you are facing is that you have lost your data and you want to back your data by recovering through any of the MAC software. This is very easy just make the Google search and it will show lots of software available to you on which you are easily recover your lost data and these software’s are very easy to use so make these software. So by these software you will get back your hard drive data in it original form so try these software’s these are not harmful for your system so try them calmly. Hope this solution will help you get rid of the problem.
Answered By 50 points N/A #88951
If you haven't used a Mac data recovery software yet then I would suggest you to use one. A Mac data recovery software scans all the drives and partitions of Mac and locates for lost and deleted data. Try a demo version of Stellar Phoenix Mac Data Recovery first –
  • Download the software.
  • Select HDD or volume and Start scan
  • All recoverable files are previewed and listed in front of you.
  • You can choose the files to be recovered and save on your system.
If you want any help then you can contact me here.
