Get an error in asa config editor for my laptop
Hello, I want to use asa config editor in my laptop. I am using windows 8 beta version. I need to know about the software and references. Experts I want to know the software will supports to my computer? Please reply soon. Thanks.
Answered By 70 points N/A #142874
Cisco ASA unites with the commonly installed real evaluation firewalls under the industry with the following group of firewall capacities. You can merge multiple enterprise-class, and the following generation group of connections safety mends without surrendering on the Cisco ASA firewall performance.
Method on Installation on Microsoft Windows 2008:
Finish the next steps to configure the PIX-to-ASA migration tool for Windows:
  1. Go to the Cisco Software Center webpage on the link below and download the PIXtoASAsetup.exe case:
           https://software.cisco.com/download/navigator.html?a=a
     2.   Double-click the PIXtoASAsetup.exe file. Then the PIX-to-ASA migration Tool installation wizard will appear.
     3.   Click Next. The Objective Folder display Will come out. (Elective) To change the set up site, perform the next steps:
            a. Click Change.
            b. Check the necessary requirements to set up a site.
            c. Click OK.
  1. Click Next. The Setup Sort screen will become visible. Select the setup type that you want and click on Next. You can choose between a complete set-up or a settlement set up. For Custom Installation—you can choose the process you wish to set up. After ticking next, the convention Setup screen appears. Total setting is up—Installs everything. After clicking on  next, the Ready to set up series screen appears.
  2. Choose which constituents that you do not want to install by going on the disk symbol then to the constituent, to select this feature will not be available, and then click Next. Go to the constituent surname to check an explanation of the constituent.
  3. Click Install.
  4. Click Finish to close the setup Wizard, when you are done with the set up.
