Hi, I have created automatic fax software by using Visual Basic. Unfortunately I got an error from VB. The error is “.net.” When I open my software it usually comes. So please help me to resolve this error and tell me why is it happens. Thanks.
Get an error in automatic fax software
There are many issues related to Visual Basic. You have to notice some points related to this software to resolve your problem.
1. In order to fix this problem, you are required to jump around within procedures.
2. You can control errors by using good programming practices in the Visual Basic 6.0.
3. The code specification is important to resolve the matter.
For the further information you can visit the given website.
https://msdn.microsoft.com/en-us/library/ms973849.aspx
