Get an error while setting up MS office Professional 2010
Microsoft Office Professional 2010 (Technical Preview) encountered an error during setup
Error 1706.Setup cannot find the required files. Check your connection to the network, or CD-ROM drive. For other potential solutions to this problem, see SETUP.CHM
Close
Microsoft Office Professional 2010:
  • Why Microsoft Office Professional 2010 encountered an error during set-up?
  • What do Error 1706 stand for?
  • What is the required files i need to set this Microsoft Office Professional 2010?
Best Answer by Gabrielle Bocha
Answered By 0 points N/A #163106
Before installing any software you should check the current configuration of your computer. However, you did not mention the current configuration of your computer. Though most of the software is made compatible with all systems, MS Office Professional 2010 is not compatible with Windows XP Service Pack 2 (“Setup cannot find the required files”).
You need to update it as Service Pack 3. You can update your computer and install MS Office 2010 on your computer. This time it will be ok.
I hope you understand it.
Answered By 0 points N/A #163107
Hi Jack,
This error occurs when you click on Cancel when you are asked to insert the installation disk.
Files in the administrative installation has files uncompressed while the CD installer has the files compressed.
Here are the solutions you can try:
  • Use an Alternative Network Admin Installation
  • Make an admin installation on your Hard drive
  • Use a CD for the Office Source Location
You can check this link to see the detailed instruction to the solutions listed above.
