I want to receive event information in triggers in PL / SQL. I have to add a trigger in Oracle which is raised or update a particular table. Inside the trigger, I want the event to determine the trigger (if insert or update) causes. How do I determine the event information in SQL PL?
Get event information in triggers in PL/SQL
Hello, How are you? You can solve the issue using the “INSERTING” and “UPDATING” keywords. Now use the following command to solve this issue :
IF INSERTING
THEN
<<do something>>
END IF;
IF UPDATING
THEN
<< do something else>>
END IF;
So, you have to write the above written command for inserting and updating keywords. That is exactly it.
Moreen Jamnelly.
