Get marvelous features of Adobe Photoshop Lightroom version 6.0
Is it capable of performing of photoshop function such as add, remove, alter the appearance? Can this operate on files? Is Adobe Photoshop Lightroom similar to Adobe Bridge? What is the Library concept in it? Can I create web gallery by using Adobe Photoshop Lightroom and how doing this? Is it supported on XP operating system? How does Panorama Merge utilize? Is it supported by all types of video format files? What is an email directory function available in it? Thank You
Answered By 0 points N/A #171485
           The Adobe Photoshop Lightroom is an image organizer and photo processor created by adobe systems for Windows OS x. The light room has edit a non destructive.
            However the name adobe photoshop has incapable of adobe photoshop functions and adding, removing or altering the appearance of image items. The 3D objects are modifying the individual video frames.
            The Adobe Lightroom is not the file manager like adobe bridge. It cannot operate on the files unless they imported the files into the database.
            So the Lightroom has accepted the recognized different type of image formats.
