Get marvelous features of Cougar 600K Mechanical Gaming Keyboard
What are key switches using in Cougar 600K? What is mean by N-Key Rollover? Is Cougar 600K supported USB mode or wireless?
What are the gaming types available there? How many USB ports available in it? What is the material using in Cougar 600K keyboard?
How are cable length, dimension and weight available? Is it better gaming keyboard for mechanical key switch technology?
Give me some idea as about its backlight facility. Can I adjust backlight?
Thank You
