Get Microsoft Windows 7 Technical Support Phone Numbers
Hi, I am facing problem with my windows 7 operating system. I have recently purchased the licensed windows 7 versions from Microsoft online store. Now there are some software which are not working. Can anyone help me please? Should I contact local dealers or someone else to resolve this problem? Can you provide me Microsoft windows 7 technical support phone numbers on which I can solve my problem? Reply ASAP. waiting for experts to reply. thanks, in advance.
Answered By 0 points N/A #288747
Hi there, here are some of the Microsoft Windows 7 technical support phone numbers which may help you. If you are facing some technical errors or software problems with Microsoft products bought online or elsewhere you should contact a toll-free number of Answer Desk of Microsoft i.e. 1-800-642-7676.
You can also contact to customer support number of Microsoft i.e.   1-877-696-7786 or technical support number i.e. 1-877-696-7786. For further information, you can visit this site . Hope my answer proves beneficial for you.
Answered By 590495 points N/A #302335
When you purchase and install Microsoft Windows 7 on your computer, it is not the operating system’s responsibility to make the program compatible and work on your computer. It is actually your responsibility to check the applications you install on the computer if it is compatible or not. Before installing any software on your computer, make sure the application supports Windows 7 and your hardware meets the requirements.
When I say “hardware,” what I mean is the processor, RAM, video card, sound card, and others. The hardware refers to the devices that make up your computer. You need to check the program’s system requirements before literally installing it on your machine. It doesn’t only apply to the software you install.
Checking the system requirements is also very important when installing devices like network card, video card, and sound card. Before purchasing any device, you should check first if its driver or the software that comes with it is compatible with your operating system.
