Get new avg 2012 skins
Hello IT Experts,
May I customize my old Antivirus by adding the latest avg 2012 skins ?
If yes, may you please explain me how ?
Thank you for the help.
Best Answer by Khall Sherry
Answered By 0 points N/A #150421
Hello Brien Bradshaw,
If you want to customize your old AVG Antivirus with a new AVG Antivirus skin 2012, for this you have to install the new AVG Antivirus 2012. Then you can get new AVG Antivirus skins.
It cannot happen that you use old or any other antivirus software and you are able to customize it with new AVG 2012 Antivirus.
Answered By 0 points N/A #150422
Hi
As per my knowledge there is no skins available for avg 2012 anti Virus. Once you update your antivirus from lower  version to higher version only its database regarding viruses updated. antivirus company maintain its simplicity so that it is convenient to operate it but if you still want to change then try this one – Smadav Antivirus.
Smadav also very light and fast in scanning, especially for SmadAV Pro version.
Smadav is very compatible with other antivirus.
Thanks
