S.Jabeen
Posted on - 09/20/2016
Hi, I recently got shifted to my new house. My printer worked fine before it got messed up with some issue. My hp wireless printer won’t connect now as I try. Do I need to re-install it? What is the issue?
To Get A Solution For The Hp Wireless Printer That Won’t Connect.
When you were in the process of shifting, you might have reset the settings of your printer by mistake. The router might have been reset to its default settings. You have to make each other communicate again. For doing so, you need to check whether the WER and SSID possess the same information in the printer.
For doing this, you have to get the information in the network as well as the printer itself. Enter the information (SSID or WPA key).
