F Samuel
10 points
Posted on - 09/02/2016
Hi. I have recently started using MS-Outlook. However, there are some issues coming up with the application which is why I uninstalled it. How to reinstall Microsoft Outlook? Please reply ASAP. Thanks in advance.
Get Techy By Learning How To Reinstall Microsoft Outlook
Hi. To learn how to reinstall Microsoft Outlook in Outlook 2016, open the control panel, select the option to add or remove programs, click on MS-Outlook and then select change. Following this, reinstall button needs to be clicked on and then click on next. Then, select the option for detection and repair and finally follow the instructions to install the application.
Alternatively, for Outlook 2003, click on control panel and then select programs, and then programs and features. Select MS Office 2016 from the list of programs and then select change. Next, click on quick repair and then repair to install the application successfully.
Hope we helped.
If you are using Microsoft Office Outlook as email client and you want to uninstall it, there are two ways to do it. If you installed Microsoft Office Outlook as a separate program, you can uninstall it in the Control Panel or use Revo Uninstaller for a much cleaner removal. Download the free version of Revo Uninstaller and install it.
Once installed, start Revo Uninstaller then select your Microsoft Office Outlook among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, close Revo Uninstaller then restart the computer. On the other hand, if you have the entire Microsoft Office suite installed on your computer, you can disable Microsoft Office Outlook as a feature which is also like uninstalling it. Click “Start”, “Control Panel” then “Add or Remove Programs”. In “Add or Remove Programs” window, scroll down and select your “Microsoft Office” suite and click “Change”.
On the next screen, make sure “Add or Remove Features” is selected then click “Next”. On the next screen, click the down arrow for Microsoft Office Outlook and select “Not Available”. Click “Next” then wait until it is complete. When it is finished, close all windows and restart the computer.
To install it back, repeat the same steps then in the down arrow, select “Run from My Computer” or “Run all from My Computer”.
