Could anyone help with finding the best wifi network monitor software available for the following Access Points and Wireless controllers :
Cisco, H3C, 3Com, Colubris
I do know that sometimes a single management Software can do the job perfectly, but I would like to know the one which fits my needs depending on the material I am using in each situation.
Get wifi network monitor software for different manufactures
Dear Chris,
I would suggest the PRTG. They even have free ware to try their product. It is available with network routers, the Cisco system or other known as Cisco routers. And try to see Ming Software try it with your Lan Controller. You may want to visit some routers that you provided: www.3com.com, www.colubris.com, www.cisco.com. Some support will give you info of what is the best network monitor software. PRTG can make your job much easier and not only that it is also fits your budget.
Thanks,
Steeley Ney
