Kerosi Yap
5 points
Posted on - 05/09/2017
Hi, I’m using Windows 7, unable to connect to the internet. So I did troubleshoot then it told me that I don’t have a network adapter. What is a Network adapter and how can I install it. Thanks in advance.
Getting Adapter Not Found- What Is A Network Adapter? Where Can I Found It?
Hi, when computer operating system didn’t find drivers to connect its physical component it displays such error. So please check your network adapter drivers installed or not through device manager. If not installed then install them and restart your PC else you installed already then the open system in safe mode remove NIC, other network adapters restart PC and install drivers. Still, faces the same problem add a new Network Interface Card (NIC) externally through either USB port or PIC slot.
