Getting An SCCM Error Code 0x87D00324, What To Do?
I am getting an  SCCM Error Code 0x87D00324, it says,”Unable to make changes to your software” and when I click on more information, it says that “the software change returned error code 0x87D00324”. Can you please give me a website which has a list of error codes for SCCM2012?
Image result for SCCM Error Code 0x87D00324
Answered By 10 points N/A #294371
This error code indicates that your installation was successful, but the detection method didn’t work on the software as installed. See AppEnforce.log double check.
And to answer your question, there is no single website to tell you all the errors; you have to use forums for solving them. Though you can use a software called CMTrace, which can decode some of them.
